I need help...pretty please!
  • southerncurlyq
    • Jul 2006
    I am getting aggravated. I have unistalled dbpowerAMP twice and reinstalled and i am still having the same problem. I
    t is telling me this....
    The CODEC required to compress 'C:\Documents and Settings\Natasha\My Documents\My Music\New Converted\107-paul_wall-sittin_sideways_(feat._big_pokey).wav' could not be opened.
    This is when I try to convert a mp3 to a wav. I am sure I will have to download a codec, but it doesn't tell me which one.
    Any help would be greatly appreciated!
    Re: I need help...pretty please!
    What are the specs of the mp3 (bitrate, frequency, channels) and what kind of wav did you select for your output (with all specs)?
    • southerncurlyq
      • Jul 2006
      The one I tried yesterday is Bit-204, Frequency-44100, Channels-2 and the wav I selected was MPEG Layer 3,18kbit/s, 11,025 Hz, stereo.
        • 43928
        There will be a problem with the wave acm compressor, if you tried a normal uncompressed wave (PCM) I am sure it would work. It is a good test to try.
        • southerncurlyq
          • Jul 2006
          Thanks so much for you help!!! I got it working :smile2:
