[Bug] dBpowerAmp Mac R16.2 : ReplayGain effect not remembering the dB in LUFS
  • 3rik
    • Oct 2010
    • 36
    So I'm using R16.2 under macOS Sierra 10.12.6.
    I wanted to use the ReplayGain "effect" to change the LUFS value for my AAC collection with Batch Converter.
    How to reproduce the bug :
    1) Run Batch Converter
    2) Select the AAC music library
    3) add the RG effect.
    4) go to its settings and change default LUFS value (-18dB) to what you want
    5) Close the RG effect settings
    6) Open it again : It's set back to -18dB
    Please fix this
    Best,
    Eric
    • 4015
    Re: [Bug] dBpowerAmp Mac R16.2 : ReplayGain effect not remembering the dB in LUFS
    Please fix this
    Fix what, exactly?
    • 3rik
      • Oct 2010
      • 36
      Fix what, exactly?
      Sorry, maybe you don't understand me 'cause of my bad English...
      The bug is with Music Converter and the ReplayGain plugin : Change the LUFS value to what you need, close the Replaygain Plugin, re-open it and you will notice that it's back to its default value (-18dB LUFS) : It doesn't save the value you enter...
      Hope you'll understand now
      Best,
      Eric
        • 4015
        OK, I understand now. BTW, what LUFS value did you enter?
          Super Moderator
          • 1368
          Thanks for reporting, bug confirmed and fixed for the next update.
          The real bug here is that we only use the target volume with EBU R128 calculation but do not disable the edit box when ReplayGain (not RBU R128) is selected. If you switch to EBU R128 calculation, the target volume will be remembered.
          • 3rik
            • Oct 2010
            • 36
            I'm sorry, English isn't my native language... I don't understand how to get the target volume remembered :(
            As I can't wait for R16.3 to be released, and -12 dB LUFS is needed for my whole FLAC library, could you explain me once again ? (maybe you could post pictures or use simple words)
            Thanks for your help !
            Best,
            Eric
              • 43991
              Use EBU R128, not Replaygain
              • 3rik
                • Oct 2010
                • 36
                Hello, issue not fixed in Mac R16.3, see pictures :
                - Use the Batch Converter then :
                Choose the LUFS value :
                Close the settings window and reopen it to check if settings are store : NO
                Please fix this for Mac R16.4
                Eric
                  Super Moderator
                  • 1368
                  Problem confirmed and fixed for the next update.
                  In meanwhile, if you defocus the editbox before dimissing the dialog, the edited value is remembered.
