How to batch convert mp3s from ID3v2.3 to ID3v2.4?
  • timster67
    • May 2014
    • 210
    Apparently v2.4 is better than v2.3 for handling multiple artists and other things. So I have changed dbPoweramp codec configuration for encoding mp3s to use id3v2.4. I had hoped using the ID Tag Update utility would rewrite the tags with the new version, but it seems not.
    Do I need to set something in the manipulations to rewrite the tags with the newer version?
    • 43928
    Re: How to batch convert mp3s from ID3v2.3 to ID3v2.4?
    ID Tag should do this, if you have dBpoweramp configured to write 2.4 then ID Tag update will write that new version.
    • timster67
      • May 2014
      • 210
      Hi Spoon. That's what I thought it should do. But I have tested it on one album and the ID tags are the same before and after.
      Here's the advanced codec configuration setting - mp3, ID3v2 version set to 2.4:
Name:	Advanced Codec Configuration.JPG
      and here's what mp3tag says after running ID Tag Update on the album - still at v2.3:
Name:	mp3tag after running batch convert.jpg
      I've not set any options in the utility codec other than ID Tag processing, but it did do something in the progress window. I unchecked preserve file time and reran. It was so quick the "Completed in.." time was blank. The file was rewritten according to the file modification time though.
        • 4015
        [ATTACH=CONFIG]2210[/ATTACH]
        The mp3 ID Tagging >> Tag Creation option is wrong, as you have not selected ID3v2, rather APE2 & ID3v1.
        • timster67
          • May 2014
          • 210
          OK, selected ID3v2 in that option as you suggest. Made no difference I'm afraid. Still won't convert from ID3v2.3 to ID3v2.4. Seems to think as it's already at ID3v2.x it needs do nothing?
            • 43928
            Do the files have write access? try converting mp3 >> mp3 (in another location) as a test, this 100% creates new ID tags, what tag type is written?
            • timster67
              • May 2014
              • 210
              Hmm. That's interesting. mp3->mp3 with a new destination and they are still at ID3v2.3.
              So, I tried converting flac to mp3, and they are also v2.3.
              And yet the codec configuration is definitely as the image shows - v2.4
              I must be missing something?
                • 43928
                If you close the configuration and then look again does it say 2.4?
                  • 4015
                  What version of dBpoweramp are you using?
                  ... to confirm, I just tested a flac to mp3 (ID3v2.4) conversion in dBpoweramp Reference (registered) R16.5 and the resulting mp3s are showing as ID3v2.4 in MP3Tag.
                  • timster67
                    • May 2014
                    • 210
                    @Spoon, yes configuration's on v2.4 since I changed it yesterday morning. Interestingly, or confusingly, the Tag Creation was at ID3v1 and had been since installing it, until I changed it at mville's suggestion. And yet batch converting has always been to ID3v2.3. Most odd.
                    I'm using Registered Reference R15.3 (and seeing as the v2.4 option is in the configuration, one must assume I don't need 16 for it to actually do so).
                    I wonder - dBpoweramp configuration requires admin permission, but I run converter as a non-admin user. Could that be the issue?
                      • 43928
                      It is likely something on your system means the configuration program is writing its settings to a different location than can be read by music converter. The converter runs non-elevated, and those settings are stored non-elevated. Which security software do you have?
                      • timster67
                        • May 2014
                        • 210
                        I used to have Norton 360, just recently changed to Norton Security.
                        • timster67
                          • May 2014
                          • 210
                          Yup. Just logged in as admin and ran a test mp3->mp3 conversion. And they came out as ID3v2.4
                          I'll do the batch conversion as admin, but I'd like to know how to get it to work for a "non-admin" user for when I do any future flac to mp3 conversions.
                            • 43928
                            It is likely your security software is interfering with normal operation. dBpoweramp runs normally in admin or non-admin accounts.
                            • timster67
                              • May 2014
                              • 210
                              I have no idea how to determine if that is the case. Any pointers? Is it program control? They are all to do with internet and network access as far as I can see. Firewall? I have dBpoweramp allowed.
