CoreConverter.exe Crash
  • 818_Papi
    • Jan 2007
    Lately I've been getting a crash of CoreConverter.exe at the end of encoding a file to MP3 I think its when it writes the ID3 tags 'cause the files are playable. I get this error when using the LAME encoder and the Fraunhofer IIS encoder. I understand its still in BETA. Is this just a bug in the BETA and won't be present in the final release. Its annoying to have to click 'Don't Send' every time it crashes I rather just let it be and only interaction would be when I move the songs to their appropriate directories.
    BTW, when I click to view the error report a DLL that it mentions is mp3.dll. Is there a way to make this error from occurring ever again?
    Below is the error I'm getting.
    Re: CoreConverter.exe Crash
    Is this the latest beta 4? Did you have any previous beta installed before this one? If so, did you uninstall the old version before you installed the new version?
    Version numbers are found in "dBpowerAMP Configuration" located in the Start Menu under Programs --> dBpowerAMP Music Converter --> Configuration.
    You might have a corrupt install. Do a total uninstall mentioned here: http://forum.dbpoweramp.com/showthread.php?t=6828 and then reinstall the latest beta.
    • 818_Papi
      • Jan 2007
      It was the latest beta i installed but im gonna try a total uninstall and see if that fixes it.
      • 818_Papi
        • Jan 2007
        Thanks it worked.
        • vinnie97
          • Dec 2003
          • 24
          I'm having a CoreConverter problem when using the CLI Encoder (it happens with FLAKE and Vorbis AoTuV 5). A few minutes into a batch encode, the dbpoweramp program will freeze and I lose access to my taskbar. The only way to regain control of the PC is via a hard reset. Upon checking the running processes (which I am able to do),I notice about 8 CoreConverter.exe's running, none of which I can manually close. Killing and restoring explorer.exe yields no results and the computer fails to shut down or restart without a hard reset.
          Some pertinent specs are Windows XP Pro w/ SP2 with the E6700 Core 2 Duo and an MSI 975X PowerUp Edition motherboard and 1GB of Corsair 8500C5 (downclocked to 667 MHz). Dbpoweramp release 12.
          Anyone else experiencing this?
          • vinnie97
            • Dec 2003
            • 24
            To follow up, this doesn't seem to occur with the official dbpoweramp FLAC encoder (1.1.2).
            Perhaps I should've created a new thread...but will let this one ride out a little longer before creating one.
              • 43930
              I have seen reports of this before, try configuring the cli encoder to write a temporary wave file instead of using stdio.
              • vinnie97
                • Dec 2003
                • 24
                Thanks for the feedback.
                Here are the command lines that yielded the crash:
                FLAC (Flake SVN revision 117): -12 [infile] -o [outfile]
                Vorbis [(Lancer 20061110(Based on aotuv-b5_20061024)]: [infile] [outfile] -q -0
                [infile] is the equivalent of writing a temp wav file, yes?
                  • 43930
                  [infile] does use a temp file, which program was crashing, coreconverter or flake?
                  • hanschke
                    • May 2006
                    • 79
                    got this error under vista business today too :(
                    02 - artist - title (rmx).mp3
                    i want to convert to 128 kb mp3 into the same folder.
                    [edit]
                    status is at 100% and than it crashed. other files from the album work fine.
                    [edit2]
                    so i miss 3 seconds of the song :(
                    Error converting to mp3 (Lame), 'F:\Playliste 2007\add\artist - title (rmx).mp3' to 'F:\Playliste 2007\add\artist - title (rmx).mp3'
                    Error: Watchdog timeout, possible CoreConverter crash
                    and the vista error:
                    Dateien, die bei der Beschreibung des Problems hilfreich sind:
                    C:\Users\Administrator\AppData\Local\Temp\WER2CD5. tmp.hdmp
                    Lesen Sie unsere Datenschutzrichtlinie:
                      • 43930
                      Using the latest Release and latest codecs (as listed in the beta thread), you are ripping a cd to mp3?
                      • vinnie97
                        • Dec 2003
                        • 24
                        Yes, CoreConverter seems to run multiple instances that I can't close when converting with either [(Lancer 20061110(Based on aotuv-b5_20061024)] or Flake.
                        • hanschke
                          • May 2006
                          • 79
                          i use the latest release. i have installed 11.5 registered and update it to 12er.
                          i take the vbr mp3 and want to make a cbr mp3. dont need the best quality. all other files worked but not this one.
                          i can send it but it is against the law and so we cannot see if it is my pc or the file that it is not ok :(
                            • 43930
                            hanschke
                            if it is repeatable then please send the file:
                            (it is not against the law for me to have the file for testing).
                            vinnie97
                            you have left it for awhile, the compression to a wav file is done at the end (ie it might look like it has locked up, leave it a minte or two).
                            • hanschke
                              • May 2006
                              • 79
                              yes it is repeatable so i will send u the file
