CD Ripper can't access metadata providers
  • klaatu
    • Feb 2003
    • 22
    All of the metadata sources are grayed out for me in CD Ripper (v 16.4), which I just installed on my new PC. I gather from what I’ve read elsewhere that the likely reason is my security software (Windows Defender Firewall) is blocking program access to the web. I created new inbound & outbound firewall rules to allow CDGrab.exe access, but it was no help. Are there additional .exe files I need to whitelist to be able to get metadata?
    Oddly, the ripper was able to identify the CD I used to calibrate AccurateRip, and its Freedb entries were displayed then, but I’m unable to manually get metadata from any source.
    • 43936
    Re: CD Ripper can't access metadata providers
    You must not have the registered version installed, you need Reference installed to access all the providers, the free version of dBpoweramp, or the Power Pack version will just allow access to Freedb.
    • Sotosound
      • Jun 2021
      Hi
      I'm having the same issue myself on 21st June 2021.
      I have the registered version installed (Order Number <edit>), and I experienced the issue both before and after upgrading from V17.2 to V17.3 today.
      This means that I have just had to edit all of the metadata for "The Best Of Neil Sedaka" prior to ripping because both DBPoweramp and my Bluesound Vault 2 resolved it as "Great Big Fun" by Tom Chapin.
      It's now ripped with the correct artist and track titles as a result of my work, but the album cover remains incorrect.
      How can I explicitly activate the review of metadata from individual providers?
      Many thanks.
        • 43936
        Click the red label looking icon on the toolbar.
        • Sotosound
          • Jun 2021
          Originally posted by Sotosound
          Hi
          Many thanks.
          PS I can access the providers individually using "Retrieve Metadata From", but the "Review PerfectMeta Matches" screen has Discogs, GD3, Music Brainz, and freedb greyed out.
          • Sotosound
            • Jun 2021
            Many thanks, Spoon. Missed your reply, but as per above, the providers are all greyed out.
              • 43936
              Under the green options button >> active providers >>
              ensure the top 5 are selected. Then press the blue refresh button
              • Sotosound
                • Jun 2021
                I'll try that.
                Many thanks.
                • SCAndrews
                  • May 2021
                  How do I know if my version is "registered"? I paid for the thing so I assume it's registered, but can't find a way to confirm this.
                  Is there a way?
                    • 1748
                    Start dBpoweramp Control Center ("Configure dBpoweramp"). In the upper left corner is the hint.
                    • AudioDOctor
                      • Jun 2021
                      I don't know if I am having the same problem, or a different problem but...
                      I can access the metadata providers it just take a very long time... up to a half hour to finish retrieving the metadata.
                        • 43936
                        See:
                        R2023 included many updates to the ever changing metadata landscape, in the recent years: All Media Guide (AMG) service has been discontinued freedb.org has also been discountiuned musicbrainz updated their servers, resulting in R16 or older not being able to read the metadata R2023 addresses all these issues and providers
                        • AudioDOctor
                          • Jun 2021
                          I can't reply there so I will do it here. I am using 17.4
                            • 43936
                            Check the date and time on the computer is accurate. If still no go, try to restart the computer in safemode with networking and see if metadata comes in quickly:
                            • AudioDOctor
                              • Jun 2021
                              https://support.microsoft.com/en-us/...4-b3e5e56fe234
                              I am on a Mac... I have restarted the computer.
