How do I listen to my ripped flac files in itunes?
  • armanderek
    • Aug 2018
    I just downloaded the dBpoweramp application and ripped my first CD. I found the FLAC files in my itunes file but they don't appear in my itunes library and I cannot listen to them. Is there a way that once you rip the CD's they automatically appear in my itunes library?
    • 4015
    Re: How do I listen to my ripped flac files in itunes?
    Currently, iTunes does not support the flac file format.
    • armanderek
      • Aug 2018
      What can I use instead of itunes?
        • 43983
        Using Windows or OS X?
