Raspberry Pi3 Asset Questions
  • RaspberryAsset
    • Feb 2018
    • 40
    After many hours and reading from lots of different sources I now have Asset working on a headless Raspberry PI.
    I have it connect to a NAS that stores my music.
    A few things I could not figure out. Where does Asset store the database for the music.
    When Raspberry PI reboots and Asset starts it shows no files and needs to do a rescan. Can it be set to do a rescan after every start?
    Super Moderator
    • 1367
    Re: Raspberry Pi3 Asset Questions
    On Linux, Asset's database by default resides in your home folder, under ~/.dBpoweramp . Unfortunately on some Linux distributions the home folder is not suitable for this.
    You can specify where you want Asset storing your configuration by setting the _APPDATA_OVERRIDE environment variable prior to running Asset.
    Example:
    export _APPDATA_OVERRIDE=/var/AssetData
    ./AssetUPnP
    Replace /var/AssetData with a suitable location within your Linux filesystem with sufficient free space (Asset caches album art of your albums there which may require quite a bit of space depending on your music library).
    • RaspberryAsset
      • Feb 2018
      • 40
      Hi Peter
      Thanks I was able to find the database and there is still lots of room on the card, so it is suitable where it sits.
      When I do a reboot the computer the data base is gone. Is that correct? Also is there somewhere I can put a command in to do an automatic rescan of the of the folders in Asset after a reboot?
        • 43980
        It is not asset which is wiping that data, you need to investigate what is, try writing another file to that folder and reboot the pi, does it also get deleted?
        • RaspberryAsset
          • Feb 2018
          • 40
          Hello Spoon and Peter
          My mistake it is not deleting the file. But it starts up with no files showing on the web interface and it shows as an empty library on my music client. Can I have a rescan start after every bootup or why is showing no files after bootup?
            • 43980
            For it to show 0 files on restart, the database file must be being wiped, check its size before a reboot and after.
            • RaspberryAsset
              • Feb 2018
              • 40
Name:	before and after reboot1.jpg
              Here is a picture showing before and after reboot.
              Any idea why this is happening?
              • RaspberryAsset
                • Feb 2018
                • 40
                Did you look at the picture from my last post?
                Thoughts?
                  Super Moderator
                  • 1367
                  The folder where your Asset configuration is placed must be on some kind of a RAM drive that does not survive reboots. You need to redirect it somewhere else. For an example, to the same folder where your Asset binaries are located.
                  Use the _APPDATA_OVERRIDE as shown in my post above to choose another folder to store your Asset data.
                  • RaspberryAsset
                    • Feb 2018
                    • 40
                    Hi Peter and Spoon
                    I am sorry but I am new to Linux and I cannot figure this out. Can you walk me through this?
                      Super Moderator
                      • 1367
                      What is the location of your Asset application folder?
                      What command do you use to start Asset?
                      Let's presume your Asset application folder is something like /var/myAssetInstallationPath - replace it with your actual path before running these commands.
                      You start Asset using something along these lines:
                      /var/myAssetInstallationPath/AssetUPnP
                      or
                      cd /var/myAssetInstallationPath
                      ./AssetUPnP
                      Before starting Asset, set an environment variable telling Asset the desired location under which ".dBpoweramp" folder should be created-
                      export _APPDATA_OVERRIDE=/var/myAssetInstallationPath
                      Note that if /var/myAssetInstallationPath contains space characets, extra quotation marks will be needed around it for the above to work.
                      • RaspberryAsset
                        • Feb 2018
                        • 40
                        Thanks for your help.
                        I tried this
                        set export _APPDATA_OVERRIDE=/var/Asset/Asset-R6-RaspberryPi-registered/bin
                        /var/Asset/Asset-R6-RaspberryPi-registered/bin/AssetUPnP
                        But it did not seem to work.
                          Super Moderator
                          • 1367
                          No "set"
                          • robinp
                            • Jan 2019
                            No "set"
                            Hi Peter,
                            Thanks for the information on setting the path for Asset files. I can successfully make the change manually prior to starting Asset and have verified that the data is written to the correct location. However, I start Asset at boot and do so with @reboot /usr/bin/asset/bin/AssetUPnP in a cron file. Can the export _APPDATA_OVERRIDE=[my specific path] command also be added to the cron file before the @reboot /usr/bin/asset/bin/AssetUPnP command? So the cron file entries would look like:
                            @reboot export _APPDATA_OVERRIDE=[my specific path]
                            Robin
                              • 43980
                              you would be best using a .sh script to do this, this might help you get started:
                              A survey of techniques by which the shell user can express more without getting bogged down in tedious repetition, and tie together various tools within the GNU/Linux environment.
