dBpoweramp 64 bit and 32 bit Compatibility
    • 46198
    The 64 bit release of dBpoweramp will only work correctly with 64 bit codecs. In Codec Central the codecs which are indicated as 32 bit only will not work with the 64 bit version of dBpoweramp. As the 32 bit version of dBpoweramp has been retired, on the registration download page is an 'Old OS?' link, click that to download the last 32 bit version, then force install the older version.
    CD Writer
    CD Writer cannot be compiled to 64 bit, it is 32 bit only.
    • 46198
    Re: dBpoweramp R15 Compatibility
    What Can I do if I need R15 to work with a 32 bit Codec / CD Writer?
    It is possible to force dBpoweramp R15 to install as 32 bit (both 32 and 64 bit versions are included in the same install), to do so:
    a) Uninstall all dBpoweramp programs from the 'Programs and Features' entry in Control Panel
    b) When running the dBpoweramp install hold the right shift key down before and whilst you double click the install, this forces the 32 bit install to run, this is the right shift key:
    On the installer if it tries to install dBpoweramp to: C:\Program Files\dBpoweramp then the 64 bit version is installing, if installing to C:\Program Files (x86)\Illustrate\dBpoweramp it is the 32 bit install.
    Note if the 32 bit version installer does not launch, you can instead: start >> run (or Windows Key + R), browse to the installer and select it, then on the end of the line add a space and:
    --force32bit
    Then click Ok to run.
      • 46198
      I have installed R15 64 bit, yet when I install a 64 bit codec it installs the 32 bit codec?
      There must be parts of dBpoweramp R14 32 bit remaining on the system, if the install detects the 32 bit dBpoweramp it will install the 32 bit codec, to overcome this:
      Open Windows Explorer and Browse to:
      C:\Program Files (x86)\Illustrate\dBpoweramp\
      Remove the file:
      dBConfig Application
      Then reinstall the codec.
      It is not possible to install the 64 bit version to location that was previously used to hold the 32 bit location, for example if the 32 bit version was installed to: C:\Soft\dBpoweramp\ the 64 bit version could not be installed to this location
