Custom ID-tags
  • JimsAmp
    • Jan 2013
    Custom ID-tags
    I have seen several post about producing custom ID tags but they refer to descriptions which I cannot find, is there a definitive instruction on how to do custom ID-tags so that I can create my own genre list.
    I also want to use windows explorer (RH select - Edit ID-tag) to edit the tags.
  • JimsAmp
    • Jan 2013
    Re: Custom ID-tags
    I can see how to create custom genre during the ripping process but I want to create a new genre listing so that I can edit my existing albums in explorer.
    On a post it was said by spoon, under file select edit id tag, I cant see file anywhere in dbpoweramp, am I missing something?
      • 46225
      Re: Custom ID-tags
      If you type a new genre into the genre box, it is remembered for next time.
      • JimsAmp
        • Jan 2013
        Re: Custom ID-tags
        OK I see how to do that in the process of changing the tag of an album or track by a right click in explorer but this assumes I want to change that feature. What I would like to do is edit the list / file where all the tags are stored so I can apply my genres where required.
        Where is the file? I have searched but cant find it.
          • 46225
          Re: Custom ID-tags
          %appdata%\dBpoweramp\Genres.txt
          • JimsAmp
            • Jan 2013
            Re: Custom ID-tags
            That's what I want, thanks for that.
            • TJoerg
              • Jan 2022
              • 22
              Re: Custom ID-tags
              Sorry, I wanted to reply with Quote. How can I delete this?
              • TJoerg
                • Jan 2022
                • 22
                Re: Custom ID-tags
                Unfortunately not. Maybe on Windows only?
                For example I write "Piano Concerto" or "Piano Sonata" in the genre-fild but if I insert a different CD and want to use, none of this New genre is shown in the list.
                  Re: Custom ID-tags
                  See post no. 5, you edit the genres.txt file.
                  I'm not sure if/where this file is located on the Apple OS.
                    • 1656
                    Re: Custom ID-tags
                    On Mac OS, the list of genres is stored at:
                    ~/Library/dBpoweramp/genres.txt
                    • TJoerg
                      • Jan 2022
                      • 22
                      Re: Custom ID-tags
                      Great! I couldn't find that hidden folder but now it works.
                      Thanks a lot!
