Asset: "Capture PC sound and stream to UPnP player" Windows7 How?
  • jockstream
    • Jan 2013
    Latest version of Asset claims to be able to "Capture PC sound output and stream to a UPnP player (Windows 7 & Vista)" - I cannot find any explanation amongst the (meagre) online documentation on how to do this. A search for this topic of the FAQ and Forum returned no hits.
    I'd appreciate help on this - it's a major reason I purchased Asset Premium
    • 45439
    Re: Asset: "Capture PC sound and stream to UPnP player" Windows7 How?
    You set something playing on the same computer that Asset is installed onto, then you play this through UPnP with Advanced Search >> PC Sound Capture [WASAPI]
    that is all there is to it.
    • jockstream
      • Jan 2013
      Hi Spoon
      Fantastic - thank's mate: you really are "da man"!!!
      • robertjwarren
        • Sep 2009
        where is "advanced search" in Asset 7? i dont see it
        • robertjwarren
          • Sep 2009
          a screen shot would help
            • 45439
            It is now under 'Additional'
