dBpoweramp Music Converter: Command Line Encoding / Scripting [Windows]
This topic is closed.
This is a sticky topic.
    • 46225
    dBpoweramp Music Converter can be called through the command line (CLI) by other programs / batch files:
    dBpoweramp Music Converter can be called in Windows from other programs through scripting (OLE):
    • 46225
    Reading Compression / DSP Settings For Scripting
    Certain Codecs (WMA, and compressed Wave) are difficult to setup as the settings are not guessable. Using CD Ripper it is possible to set the compression settings and read them back from the registry.
    Open CD Ripper, set the profile to default, set the encoder and settings as desired. Close CD Ripper then open regedit:
    HKEY_CURRENT_USER\Software\Illustrate\dBpoweramp\C DRipper\Profiles\(default)
    The settings are stored under CodecCLI_xxxxxxxx
    DSP command line is stored under DSPEffects.
