Tunefusion stopped syncing, now won't pair
  • engine
    • Jul 2021
    • 19
    Everything was fine, until, it suddenly stopped syncing at some point (I can't remember), and therefore couldn't add any more tracks to my phone.
    Just a guess: Perhaps i'd run out of space on the phone, so I thought i'd switch it to an existing folder, instead of the default for foobar, using the existing MP3 files. It won't pair. I also tried "Add a new Sync" It still won't pair.
    I thought i'd switch it back to the default folder, but, no, it still won't pair. :(
    Running Android on Samsung S22+ and PC with Windows 11. As far as i'm aware, the only updates have been the regular Windows updates.
    Any thoughts and idea are welcomed.
    Thanks in advance
    • 44714
    Re: Tunefusion stopped syncing, now won't pair
    it suggests that perhaps a firewall on the computer is blocking network access
    • engine
      • Jul 2021
      • 19
      OK, thanks.
      Not sure how I can resolve that. :(
      Any suggestions?
        • 44714
        Safe mode would normally disable any firewall, choose the 'with networking' option:
        https://www.dell.com/support/kbdoc/e...0%3E%20Restart.
