TuneFusion mobile sync was interrupted and won't sync again
  • eddardburger
    • Nov 2022
    Just what it says on the tin. Downloaded foobar2000 for iPhone and used TuneFUSION to sync my library, but the sync was accidentally interrupted. When I tried to re-sync, my phone was still in "idle" status even when it was on the sync screen, and auto-lock on the phone was disabled. Any advice would be greatly appreciated.
    Re: TuneFusion mobile sync was interrupted and won't sync again
    Try restarting foobar on the phone, and you can go into the settings to trigger a sync I believe.
    • tork
      • Jul 2023
      That's what it was, thank you Spoon.
      Since I was trying to figure it before, I used a test source folder. So foobar 2000 mobile has songs on it that I don't want and in duplicate.
      I cannot see where to delete these songs both in the iPhone and if they are on TuneFUSION also.
      What should I do here?
