Encountered 'FLAC__STREAM_DECODER_SEARCH_FOR_FRAME_SYNC' in FLAC File
  • verypsb
    • Jun 2008
    • 30
    All of a sudden I get the following error on a lot of files: "Encountered 'FLAC__STREAM_DECODER_SEARCH_FOR_FRAME_SYNC' in FLAC File". What does the error "Encountered 'FLAC__STREAM_DECODER_SEARCH_FOR_FRAME_SYNC' in FLAC File" mean? Is this a corrupt file? It's different from "md5 did not match decoded data, file is corrupt. for source file:".
    Cheers,
    Dennis.
    • 45567
    Re: Encountered 'FLAC__STREAM_DECODER_SEARCH_FOR_FRAME_SYNC' in FLAC File
    It means the file is so corrupted no data can be decoded.
    • verypsb
      • Jun 2008
      • 30
      So this means I need to re-rip the 144 files mentioned in the log files.
      • verypsb
        • Jun 2008
        • 30
        I backup daily, but lost some recent backups, around the same time TuneFUSION started complaining about corrupt files. That's Murphy's Law for you. However , I found a two month old backup, restored the files and don't get the results I would expect. The same files are still corrupted according to TuneFUSION.
        During these two months TuneFUSION synchronized those files weekly and started complaining just last week. Why didn't TuneFUSION complain some two months earlier if these files are corrupted?
        I don't see any pattern in the files that are corrupted according to TuneFUSION. Another tool, ROON, does analyze the same files and doesn't seem to have a problem with them. Some files were probably played recently, other files weren't played in a long time. What am I missing?
        • verypsb
          • Jun 2008
          • 30
          Hey @simbun,
          I took your and randomly checked some files listed by TuneFUSION as corrupted. The flac.exe test reports the same error(s) as TuneFUSION. I moved my storage to another disk somewhere in the last two months and I probably used the backup to do this. This will explain the corruption in my files. This doesn't explain why it took TuneFUSION so long to notice the corruption. TuneFUSION started complaining after I changed the source location, resulting in a complete resync.
            • 45567
            Tunefusion would not need to read the source files unless actively syncing it.
            • verypsb
              • Jun 2008
              • 30
              I think it's safe to say that TuneFUSION is good at detecting file corruption. Is it possible to schedule a "full" or "initial" synchronization periodically? To notice corrupted files earlier? Or is there another tool (Windows) I can use for scheduled testing of my music files (99% .flac)?
                • 6124
                You can simply use dbpoweramp music converter (batch converter) and select your top music folder (assuming all the music files are in subfolders to this top folder), and in Batch Converter, select "CONVERT", then for the DSP/CODEC dropdown menu, select TEST CONVERSION. This will check all your files and report if any are corrupted. It works particularly well for FLAC files, as it compares the embedded audio checksum to the calculated checksum when running TEST CONVERSION.
                • verypsb
                  • Jun 2008
                  • 30
                  Would it possible to use command line + task scheduler to exetue this task?
