folder.jpg in source to Foobar2000 mobile destination
  • ChevronLugs
    • Nov 2021
    Hello,
    I have mobile Foobar2000 installed on an Android device and I've successfully synchronized my library over to it. However, the one thing I can't figure out is how to get folder.jpg from the source to the destination. I'd prefer to not embed the artwork; just have a separate one for each album in the same directory as album files/music.
    Thanks!
    • 1645
    Re: folder.jpg in source to Foobar2000 mobile destination
    Hello and thanks for your feedback.
    It appears that the option to copy folder.jpg - or other additional files in music folders - is currently missing for foobar2000 mobile target. It will be enabled in the next update.
    • ChevronLugs
      • Nov 2021
      Hi Peter,
      Do you have an ETA for the updated file handling for mobile foobar2000 target? That's the only thing holding me back from using my licensed copy of TuneFusion.
      Thanks!
        • 46150
        Hopefully before Christmas.
        • ChevronLugs
          • Nov 2021
          That would be an awesome Christmas gift! I'm crossing my fingers, though ready to be patient.
          • ChevronLugs
            • Nov 2021
            Spoon and Peter, thank you! The change to 1.6 handling additional files when syncing to a mobile Foobar2000 target is just awesome. I'm now able to keep my various devices in sync. No more pulling microSD cards.
