TuneFusion: Change destination?
  • fastfwd
    • Sep 2011
    • 42
    Hi, Spoon.
    Once a TuneFusion sync is defined, it seems that every parameter of it can be edited -- except the destination disk/directory/server. Is there a way to change the destination? Or is there a way to copy all the other parameters from an existing sync to a new one?
    Re: TuneFusion: Change destination?
    What type of sync was it? a network / folder one? or removable disk?
    • fastfwd
      • Sep 2011
      • 42
      Thanks for the very quick reply.
      The issue is common to both sync types. The destination is shown as an uneditable string on the General & Music Library page:
      Code:
      Using Location 'Removable Disk: MUSIC256 (D:)'
      or
      Code:
      Using Location 'Local: Z:\music\Non-FLAC_to_WMA'
        The removable disc one can be set by choosing 'Options' >> 'Change Destination location'
        the network folder one cannot be changed.
