Album Art and Maximum File Size (KB) for artwork
    If ID Tag Processing > Manipulation > Album Art doesn't work as it does in Batch Converter, how do I restrict the maximum file size (kb not pixels) for embedded artwork in TuneFUSION?
    • 45569
    Re: Album Art and Maximum File Size (KB) for artwork
    Advanced Sync Options : 'Max Art Size'
      'Max Art Size' is in pixels, what I'm talking about is a restriction in the file size, in kilobytes.
        • 45569
        The next update, ID Tag Processing is working, even if files are 1:1 copied.
