Cannot choose destination location
  • varkenshand
    • Jul 2021
    Bought TuneFUSION today and installed it (three times) on a recent Windows 10 machine. No matter what I try I cannot get it working; every time I add a New Sync from a local or network folder, it adds a Music folder. But the main thing is that the Edit | Change Destination Location option does not work. It is greyed out. No idea how to solve this
    Re: Cannot choose destination location
    Please can you confirm the name of the file you downloaded and installed (three times)?
    • varkenshand
      • Jul 2021
      TuneFUSION-Registered.exe (27.595 kB)
      (which is what I got on the purchase page)
      I tried uninstall, CCleaner, and manually removed all folders in the Appdata section.
        • 46224
        Can you take a screen shot of the options page please? upload to https://imgbb.com/ and post a link here.
        • varkenshand
          • Jul 2021
          • varkenshand
            • Jul 2021
              • 46224
              They are two different things, the location of the source files is set by 'audio source' this should be your existing music collection.
              Then you set a location where you want the files to be written to, this is chosen when creating the sync, by the looks of it you have set the network share as the destination.
              You cannot sync to the same location you read from.
              Click the button '[add folder]' to add the source location of your files.
              • varkenshand
                • Jul 2021
                  • 46224
                  See my post above
                  • varkenshand
                    • Jul 2021
                    Aha! I got it just the other way around. Thought a new sync was defined by the source files... Thanks for clarifying this. All working now
                    • varkenshand
                      • Jul 2021
                      Things would be clearer if the word Target or Destination popped up in relevant places.
                      Like '[Add New Sync Target]' Or 'Destination Name' (instead of Displayed Name), and 'Using Target Location ...'
                      Just my five cents
