Not finding any FLAC files and filter by folder
  • y2jez
    • Jul 2019
    • 8
    I've gotten around to firing this up again and for some reason after indexing my library it does not appear to show any Flac files whatsoever. When I go to the filter to have a look, every file type appears apart from flac....what stupid thing am I doing. Tried synching an artist and it only drags across mp3 files. I have set it to re-encode FLAC to high comp. but it isn't finding anything.
    Secondly is there a clever way to synchronise a whole sub folder without having to manually select the metadata options you give in the software? For instance in my big Music folder. I want to be selective for artists, but then I want an entire folder included for ease where the metadata inside is a complex mess (soundtracks for instance). The current way I can only think is to give that entire folder a genre and include that, but is there another clever trick?
    Re: Not finding any FLAC files and filter by folder
    Uninstall TuneFUSION, then restart windows (full shut down, restart), reinstall TuneFUSION.
    • y2jez
      • Jul 2019
      • 8
      Yep, that fixed it. Thanks.
      What about my part two...any suggestions?
        Have 2 synchronizations, one based on the main folder which just has certain artists selected manually. The 2nd sync indexing just the sub folder.
