tunefusion question
  • Partha
    • Nov 2017
    • 158
    tunefusion question
    In the tunefusion setup, if I am transferring 16/48 FLAC files from my windows PC to the ios Foobar 2000 app (to my iphone), will the music be re-encoded to FLAC 16/48 while transferring? Also, if I am transferring Lame MP3, will the original MP3 be re-encoded to Lame MP3 all over again while transferring. thereby degrading the sound? Is there no way to transfer the files 'as-is' without reencoding?
    • 44052
    Re: tunefusion question
    Tunefusion has a section (top right) where you can set which formats are copied as 1:1, without transcoding.
    • Partha
      • Nov 2017
      • 158
      Ok, thanks. So If I click mp3 in the 1:1, it will over-ride the lossy encoding parameters on the left?
        • 44052
        Yes
        • Partha
          • Nov 2017
          • 158
          There is a problem while transferring 1:1 DSD files. They are being transferred as m4a
            • 44052
            Below the 1:1 copy section you would have to set the frequency 384KHz
            • Partha
              • Nov 2017
              • 158
