Advanced Source Filtering
  • thr4121
    • Aug 2020
    • 12
    I bought TuneFUSION for syncing with foobar2000 Mobile on iOS, and it works well for this purpose. That said, are there any plans for advanced source filtering? Specifically, I'd be interested in some sort of simple query language instead of the pre-defined selection lists, something like:
    Code:
    (Genre eq 'J-Pop' and Title contains 'Instrumental') or Genre eq 'Soundtrack'
    I actually tried to work around that by creating multiple syncs, but, alas, it seems I can't have multiple syncs with one foobar2000 Mobile instance.
    Best regards,
    Thomas
    • 46224
    Re: Advanced Source Filtering
    You would be better adding a 2nd genre to the tracks which are J Pop and Instrumental, such as: J Pop International, and you would be able to sync those.
