no autostart anymore!?
  • Miner2049er
    • Oct 2019
    • 10
    Hi there,
    TuneFUSION does not autostart with Windows 10 anymore after re-installing it. Any help?
    Cheers,
    Céd
    Re: no autostart anymore!?
    Can you manually start it by browsing to C:\Program Files\TuneFUSION and running TuneFUSION.exe?
    • Miner2049er
      • Oct 2019
      • 10
      Absolutely! I can also start it with the desktop icon.
      But autostart was way more comfortable...
        Something must be stopping the installer putting start menu, startup shortcut.
        • Miner2049er
          • Oct 2019
          • 10
          The startup shortcut IS in the startup/autostart folder but it does not start the program...!
            Try strating it from that shortcut in startup
            • Miner2049er
              • Oct 2019
              • 10
              That works. But it does not work automatically when Windows starts up...
                Perhaps it is already running, and the try icon is hidden, click ^ near the clock.
                • Miner2049er
                  • Oct 2019
                  • 10
                  No, it's not running.
                    Perhaps you have security software which prohibits the running of items from the startup. If the link works, then Windows will run the program on startup.
                    • Miner2049er
                      • Oct 2019
                      • 10
                      No, I don't think so.
                      1) Other programs do start on startup.
                      2) TuneFUSION used to startup with Windows after the first installation. Due to pairing problems I reinstalled it. And since then it does not startup anymore.
