Encoding lossy as mp3 fails
  • Oblique
    • Jul 2019
    • 25
    I want to encode my FLAC files to mp3. I've set it up like this:
    - Re-encode Lossy As: mp3 (Lame)
    - Mode: Variable Bit Rate (VBR)
    Right column: Copy 1:1 Audio Tracks Which Are: mp3 (only)
    File Naming: Sub Path\Source Filename
    Under 'Audio Types' I only have FLAC and mp3 checked.
    This results in zero (lossy) tracks being encoded. The log says this:
    Code:
    Sync started on Monday, 26 August 2019, 11:03:41 to foobar2000 on Xiaomi Mi 9 SE
    Sync incomplete.
     2 tracks, 2 tracks requiring syncing
     0 bytes synchronized
      Storing /_H/Hellfish - Black Death/Hellfish - Black Death - 01 Doctor Beak.mp3
      Unable to store /_H/Hellfish - Black Death/Hellfish - Black Death - 01 Doctor Beak.mp3
    Sync incomplete.
    Any idea what could be going wrong here?
    Thanks in advance
    • 1613
    Re: Encoding lossy as mp3 fails
    Thanks for the bug report.
    Please get the latest foobar2000 mobile beta-
    It introduces extensive debug logging of TuneFUSION operations, which should indicate in what way it failed.
    Then, follow instructions from here to get the full telemetry-
    TuneFUSION application In main window: choose relevant sync Click 'edit' button In General & Music Library panel, click 'options', 'Show Last Detailed Log' foobar2000 mobile Open Tools menu Console in Utilities section "Save" button in the upper right corner menu will cause the current content and anything
    • Oblique
      • Jul 2019
      • 25
      Thanks for the reply! Unfortunately I can't test this anymore since the trial has expired. I would buy the software after I know it works properly if you understand what I mean
      • schmidj
        • Nov 2013
        • 590
        Peter,
        Did you get the second log set I emailed you on August 5th? I'm not sure my email is getting through.
          • 1613
          ( Replied in private message with new instructions, to both )
          • Oblique
            • Jul 2019
            • 25
            Thanks for the PM Peter, things work (much better) now with the foobar mobile beta version and the info you send me through PM.
            Only really weird thing now is that when I manually want to start a sync the program instantly shuts down. When opened again it says it synced successfully. So only when there are changes detected (?) or with 'When to Sync' (currently set to 'Re-sync Every: 6 hours') option under 'Advanced Sync Options' it will sync it seems.
            Here's the TuneFusion log:
            Code:
            Sync started on Saturday, 31 August 2019, 11:28:39 to foobar2000 on Xiaomi MI 5s
            Sync started on Saturday, 31 August 2019, 11:32:06 to foobar2000 on Xiaomi MI 5s
             Library contains 162 tracks, 162 tracks requiring syncing
             Device has 72,06 GB free space, 0 bytes already synchronized
              Storing /_A/America - * 1973 Horse With No Name (1973)/01. A Horse With No Name.mp3
            ..................................................................................... (all the other tracks)
              Storing /_S/Syl Kougaï - Twinkling One (*T01) 2013/01. Twinkling Two.mp3
              Transfer error: Data stream timeout
              Unable to store /_S/Syl Kougaï - Twinkling One (*T01) 2013/01. Twinkling Two.mp3
            Sync incomplete.
            Sync started on Saturday, 31 August 2019, 11:36:52 to foobar2000 on Xiaomi MI 5s
            Sync incomplete.
            Sync started on Saturday, 31 August 2019, 12:07:03 to foobar2000 on Xiaomi MI 5s
            Sync started on Saturday, 31 August 2019, 12:07:34 to foobar2000 on Xiaomi MI 5s
             Library contains 159 tracks, 50 tracks requiring syncing
             Device has 71,22 GB free space, 281,67 MB already synchronized
              Storing /_Techno, House, Minimal (Dance)/Belief Defect - Decadent Yet Depraved (RM 178) 2017/01. Unnatural Instinct.mp3
            ......................................................................................................................... (all the other tracks)
              Storing /Somatic Responses - Circumflex (1999) [FLAC]/01 Umbrella.mp3
            Successfully completed in 2 minutes 27 seconds
            Sync started on Saturday, 31 August 2019, 12:12:08 to foobar2000 on Xiaomi MI 5s
            So in the first run it ran into an error:
            Unable to store "..."
            And when you see:
            I means that after the first run of '31 August 2019, 12:07:03' the program just instantly shuts down, but does report a successful sync. And when I open the software again it will actually run '31 August 2019, 12:07:34' and perform the actions without shutting down.
            I'm on my old phone now btw, because I don't use the Playstore anymore. So I couldn't download the beta version of the foobar app on my new phone. But on my old phone I can't retrieve the foobar mobile logs, which DID work on my new phone. I saved the logs on my old phone, but when I connect my old phone to my PC and browse that folder it's empty. While on my phone it clearly shows the logs...
              • 46064
              Look in Event Viewer >> Applications
              does it show that TuneFusion is crashing?
              • Oblique
                • Jul 2019
                • 25
                It seems so yes:
                Code:
                Fault bucket 1504646245640172192, type 4
                Event Name: APPCRASH
                Response: Not available
                Cab Id: 0
                Problem signature:
                P1: TuneFUSION.exe
                P2: 1.2.0.2
                P3: 5d4d82cc
                P4: COMCTL32.dll
                P5: 6.10.17763.592
                P6: 754444f2
                P7: c0000005
                P8: 00000000000e25b8
                P9:
                P10:
                  • 46064
                  What version Windows do you have? 32 or 64 bit?
                  • Oblique
                    • Jul 2019
                    • 25
                    64 bit
                      • 46064
                      Windows 10?
                      • Oblique
                        • Jul 2019
                        • 25
                        Yes Windows 10, sorry
                          • 46064
                          Please follow these steps:
                          1) Close TuneFunsion (right click on icon on tray >> quit tunefusion)
                          2) Download and unzip:
                          Copy TuneFUSION.exe to C:\Program Files\TuneFUSION\
                          (overwriting the existing)
                          3) Set your system up to give out details of the crash:
                          Occasionally you might be directed here to setup your system to generate a crash dump file which will enable Illustrate to locate the cause of a crash. When your system is setup in this way, any program which crashes writes its state to a .dmp dump file, it is like a snapshot of the program at the point of the crash. To set
                          4) Run TuneFUSION, when crashes email us the files created as documented in step 3.
                          • Oblique
                            • Jul 2019
                            • 25
                            I've send you a pm!
                            • Oblique
                              • Jul 2019
                              • 25
                              btw I want to ask a question about the (automatic) file naming option, can I do that here or should I start a new thread?
