Folder.jpg Missing
  • badelman
    • Mar 2013
    • 74
    Folder.jpg Missing
    Most all of my collection has a folder.jpg in each album's folder. I do have the DSP "ID Tag Processing" setup under "manipulation" as Album Art/Export to/folder.jpg for each album folder as I would like to have a folder.jpg as album art in every album folder. I just ran a pass and there is no folder.jpg in any album folders.
    1. Is this not the correct setting to move the folder.jpg and or extract an embedded copy to add if missing?
    2. A better question... how do I get the desired result?
    Thanks!
    • 46377
    Re: Folder.jpg Missing
    On the settings page for the sync >> Advanced Sync options >>
    • badelman
      • Mar 2013
      • 74
      Spoon, what is the "ID tag Processing" I have setup doing then???
      I will try that option. Thank you.
      • badelman
        • Mar 2013
        • 74
        Spoon, I'd still like to understand what is going on in the configuration I made under "id tag processing/manipulation"
        HOWEVER.. I've attached a jpg showing how I already have settings for folder.jpg in sync options. What am I doing wrong??
ID:	294104 // See: art handling and sync additional files w/extensions.
        • badelman
          • Mar 2013
          • 74
          [ATTACH=CONFIG]2454[/ATTACH] // See: art handling and sync additional files w/extensions.
          Ok.. there seems to be many places to specify what will happen w/folder or whatever.jpg. I went ahead and simplified things:
          A. I removed DSP "ID Tag Processing" setup under "manipulation" as Album Art/Export to/folder.jpg
          B. I removed any reference to .jpg files in the "Sync additional files with extension box" on the Advanced Sync Option page
          C. Chose the option(s) pictured in the attachment here for how to handle art. Click image for larger version
          Although I'm still not sure why all the places to specify what to do with art as it's confusing... however what I've done in this post WORKS!
            • 46377
            As TuneFUSION encodes to a temporary folder before transfer, the export option in id tag processing will not work as you want, this is why the option to do that has been moved to the main options page.
