BPM and Track Volume tags missing
  • badelman
    • Mar 2013
    • 74
    Hello, I'm having to go back into converted files (mp3 or flac to mp3) and add back in track volume via MediaMonkey and BPM using Mixmeister. Granted mixmeister only does mp3 for BPM but seems like more are missing. How can I make sure that the BPM and track volume that is there is carried over through the conversion? I did check into the Preserve Source Attributes DSP btut didnt seem to appear there. I'll add that I am using ReplayGain for track so still not exactly sure what that does outside of what I've specified for track gain and track peak gain. Is that the same as track volume as MediaMonkey understands it?
    Thx all!
  • badelman
    • Mar 2013
    • 74
    Re: BPM and Track Volume tags missing
    Thx all!
    Any suggestions? Thx!
      Replaygain is removed on any conversion, if you want it you should use the DSP effect 'Replaygain'.
      The BPM, try right clicking on one of the created files >> Edit ID Tags
      perhaps it has moved to a different tag?
      • badelman
        • Mar 2013
        • 74
        Thx for the solution to try on BPM. I am a little confused on your Replaygain response. IF replagain iinfo is removed but I have the DSP in place to calculate it and add to tag.. you're saying it doesn't work?
          I can see on your other thread you are asking about Volume Normalize, it would be this one which is needed, once the audio is change you do not want any replaygain ID Tags.
          • badelman
            • Mar 2013
            • 74
            So don't use track or album replay gain IF I've normalized the volume. Correct?
