Multi-Disc and Compilation Check Boxes?
  • badelman
    • Mar 2013
    • 74
    Hello, I could not find info on these boxes. If I missed it somewhere please let me know! What are the Multi-Disc and Compilation check boxes used for in the naming dialogue? Additionally, to check I ran a test and as soon as I got out of that screen and went back to look the Compilation box had cleared itself from the current sync setup. Curious as to why?
    Thank you!
    • 46146
    Re: Multi-Disc and Compilation Check Boxes?
    They just set the examples if there is a multi disc, or compilation disc. The values are not saved.
    • badelman
      • Mar 2013
      • 74
      AaHa! Ok, thank you Spoon!
