U few Issue with Tune Fussion trial
  • bradsr
    • Mar 2022
    Hello there, I have having a few issues with tune fusion trial on macOS.
    I am using it to transfer from one Nas to another.
    All seems to be working as far as I can see, however when using the the DSP filters; ID Tag processing; manipulation. when trying to export Album art, to lets say "Cover.jpg" it doesn't work..
    that the only problem I have found.
    But I do have another question if I may ask...
    1. If I have an Album artist example: Above & beyond
    2. and then have other album artist, Above & beyond & Andrew Bayer
    is it at all possible to to make the spear as Above & Beyond, so basically take the first artist and make it the album artist (Above & beyond) instead of (Above & beyond & Andrew Bayer) if this makes sense...
    As always your help is much appreciated.
    The source files have embedded album art?
    Your 2nd question, you would have to rename the album artist, PerfectTUNES can help do that for every 'Above & beyond & Andrew Bayer' it finds in one rename.
    • bradsr
      • Mar 2022
      good afternoon,
      Thank you.. Yes all the albums have embedded art..
        On the Advanced sync options page is an option to export folder.jpg, this one would work where-as the DSP effect ID Tag Processing would not as it encodes to a temp folder to be sent later.
        • bradsr
          • Mar 2022
          Good morning,
          thank you for your reply. I much appreciate your help!
          many kind regards
