Tune FUSION not syncing
  • realillusions
    • Sep 2018
    • 20
    Hiby m300 running Android 12 is not recognized by TuneFUSION on Mac.
    I was able to sync the device once, but deleted the sync due to change of miniSD cards.
    Now I can't get both machines to connect via Bluetooth, not even with the manual code.
    Foobar2000 won't activate the "PAIR" button on the code screen as if the code was incomplete.
    I've tried typing with spaces between the pairs of digits/letters, without space, CAPS, no caps.
    I don't know what I'm doing wrong.
    Please advice.
    The phone is connected by bluetooth to the computer?
    • realillusions
      • Sep 2018
      • 20
      Yes, device is able to connect via Bluetooth to desktop.
      However, I didn't have to connect as such before, TuneFUSION connected me straight away.
      Now it doesn't.
        Try removing the sync and recreate it.
        • realillusions
          • Sep 2018
          • 20
          I removed the previous sync, when attempting to create new sync is when the process failed.
          • realillusions
            • Sep 2018
            • 20
            Code pattern as shown is: XX XX ## ## X# (All caps). I've tried the following:
            XX XX ## ## X#
            xx xx ## ## x#
            XXXX####X#
            xxxx####x#
            • realillusions
              • Sep 2018
              • 20
              I can't. See original post.
                • 1685
                Bluetooth isn't in any way involved.
                Please make sure that your computer and phone are connected to the same local area network, such as your home wifi network.
                  And no firewall blocking TF
                  • realillusions
                    • Sep 2018
                    • 20
                    That was my understanding and that's why I didn't know why I had to connect via Bluetooth.
                    In a moment of infinite wisdom I had turned WIFI off and never bothered to check if it was on or not.
                    This solved the issue, thank you both.
                    I had been having different issues with a different Hiby device and that set me off track.
