Tunefusion over Tailscale
  • wittynote
    • Mar 2025
    Has anyone been able to get Tunefusion working over Tailscale or is it possible?
    • 46224
    If able to join two networks, ie you can access the network share of the remote location, then it would work.
    I use Wireguard and it works (requires ports opening and forwarding on router).
    • wittynote
      • Mar 2025
      Thank you Spoon! I was under the impression that Wireguard/Tailscale make it so no ports need to be open, but I could not get it to work. Which ports need to be open? I am able to access the network share via Tailscale in foobar2000 without issue, but Tunefusion would be very useful. Thank you for help!
        • 46224
        Setting up a WireGuard VPN server on a GL.iNet router allows secure (full-tunnel), remote access to your local network. If your GL.iNet router is connected to a primary router, such as an ISP router’s LAN port, you’ll need to configure port forwarding on the primary router to direct VPN traffic to your GL.iNet device.
