improve low resolution artwork
  • drobinson
    • Aug 2023
    Hello
    My artwork for 1000 CDs that I ripped using early microsoft player is too low for me. But perfect tunes is not upgrading it. it thinks its ok. It has found 5 tracks that it wants to upgrade. How do I tell it the minimum acceptable artwork size for me. Originally the artwork was high quality then microsoft program degraded it to lower quality.
    Also how do I find the artwork size. The files are all wav and they do have artwork but I think its stored in a folder somewhere as a .jpg
    Thanks for the help
    • 6189
    Re: improve low resolution artwork
    Are you sure that Microsoft has not embedded low quality artwork. Maybe the folder.jpg or cover.jpg is high quality and PerfectTunes sees this. But you are seeing the embedded art. Experiment with an album and remove any embedded art if it exists. Then see what art remains from the art file in the album subdirectory.
    ps never use Microsoft apps to play music or act as server. They can modify things like art without your permission.
      • 46231
      I think is 600x600, you can manually search albums individually by clicking fix.
      • drobinson
        • Aug 2023
        How can I confirm if its 600 X 600? I cannot fix 1000 CDs just don't have enough patience to click 1000 times but there may be some automation I can use here.
          • 6189
          Have you tried my suggestion.
          • drobinson
            • Aug 2023
            Yes I see the low res embedded are as blurry images in my squeezebox app. That how I know its not high quality. Now with a rip a CD with dbpoweramp or EAC the art is really great quality and I see that in squeezebox app.
              • 46231
              it is 400x400
              The next update will increase to 600x600
                • 6189
                LMS/squeezeboxes will use embedded art first, even if higher quality art is in your folder.jpg file. That is why I suggested that you open an album and delete the embedded art from the files and see if the folder.jpg starts being used. You may need to do a clear and rescan in LMS for it to pick up change as it may cache the artwork.
                • GBrown
                  • Oct 2009
                  • 422
                  Make sure you have enabled the option to view hidden files in you explorer, and check to see if WMP has added the thumbnail images there. These are very low resolution images. I would delete any of those, and disable the WMP beast.
                  There is discussion on the MS support site about these found here.
