PerfectTUNES interprets 1-Bit/11.2896 MHz DSD files as corrupt
  • Cooksons
    • Mar 2017
    • 26
    Hello,
    I recently rescanned my music library with PerfectTUNES after adding some hi-res DSD files. I found that all 3 of my albums using 1-Bit/11.2896 MHz ("quad") DSD were identified as corrupt, whereas the same albums and others using "single" and "double" DSD were not. Just curious: is this a current limitation of PerfectTUNES?
    Thanks for the great tool!
    Scott
    • 46204
    Re: PerfectTUNES interprets 1-Bit/11.2896 MHz DSD files as corrupt
    There are a bunch of files out there with ID3 tags right at the start of the file, this is not part of the DSF spec, we fix support for these files to not read as corrupted, even though technically they are.
    • Cooksons
      • Mar 2017
      • 26
      Thank you, Spoon.
      Does this mean that you are in the process of adding support for these files?
      I can also send a file to you if that would help confirm the issue.
      Thanks for the support!
        • 46204
        Yes please upload one to drop box and message me a link.
