macOS Catalina 10.15.5 Artist Tagging Issue (With Screenshots)
  • JeffBDVS
    • Jul 2014
    • 27
    Using registered version of PerfectTunes 2.5.
    I have a compilation album. I need to change the Artist metadata on a few tracks:
    I select the tracks I want to change:
    I change the artist name in the header:
    I hit return to commit the change and all the Artist tags are changed instead of just the ones I selected:
    Did I do anything wrong? I'm a PC guy who recently moved to Mac, so it might be my lack of Mac skills contributing to the issue.
    Jeff
    • 1656
    Re: macOS Catalina 10.15.5 Artist Tagging Issue (With Screenshots)
    Bug confirmed, thanks for reporting. A fix will be out shortly.
    • JeffBDVS
      • Jul 2014
      • 27
      Cheers.
        • 1656
        Fixed in new beta version-
        Current version: beta 4 Download: https://www.dbpoweramp.com/beta/PT-R2.6b4.dmg Changes since R2.5: Removed multi selection capability in add-music-folder dialog, as some users accidentally added each individual artist or album instead of the music folder itself. List of music folders is now automatically deduplicated.
        • JeffBDVS
          • Jul 2014
          • 27
          Wow. That was fast!
          Will the beta pick up my registration?
          Never mind. It did.
          • JeffBDVS
            • Jul 2014
            • 27
            New bug: I can't save any changes to tags made in the Edit Tags dialog in 2.6b3. But the bug above has been fixed.
            Do you want a new topic?
              • 1656
              Edit ID Tags dialog regression in beta 4, thanks for reporting.
              • JeffBDVS
                • Jul 2014
                • 27
                beta 4 did the trick. Thank you!
