Changing Cover Art with ID Tags
  • Threesigma1
    • Apr 2020
    Can someone suggest how to change existing album cover art? When I add new art from the Internet the program shows different art to an album even after selecting the (x) for the preexisting album art I am seeking to change. Is there a way to delete the assigned art as the initial step?
    • 46226
    Re: Changing Cover Art with ID Tags
    Which program is showing the wrong art?
    • threesigma
      • Jun 2015
      Thanks for your reply. ID Tagger is the program I am using.
        • 46226
        You are best using the 'Album Art' program in the PerfectTUNES suite for easily replacing existing art.
