PerfectTUNES Album Art Not "Remembering" Art Fix / Changes
  • Archd
    • Oct 2017
    I'm finding album art for FLAC files ripped with dBpoweramp CD Ripper. Problem is that after I find and apply album art the program is not saving applied fixes / changes. I'm saving artwork as "AlbumArt.jpg" file to a single file in each directory that FLAC files are contained , not embedding artwork in each audio file. I can find artwork, apply fix / change, close program and reopen, no PC restart, and see all "albums without art" in Music Library directory selected. I check album directory and .jpg album artwork is there - it has not been moved, changed, or deleted. Thanks for your time!
    • 46226
    Re: PerfectTUNES Album Art Not "Remembering" Art Fix / Changes
    The issue is, the program can only rescan for changes to audio tracks (which it tracks), not new jpg files in the folders. If you add a jpg, the tracks are not rescanned. You would have to do a 'Clear Database Cache', however 'AlbumArt.jpg' would not be recognized by PerfectTUNES as nothing uses this naming.
    • Archd
      • Oct 2017
      I am not seeing a 'clear database cache' option in PerfectTunes Album Art (PTAA). How do I accomplish this step? Also, what naming convention for album art do I need to use for PTAA to "remember / recognize" fixed audio files? Thanks again for you time.
      • Archd
        • Oct 2017
        Wow... sorry Spoon. I now see "Clear Database Cache" button... i would have been bit if it was a snake! In reference to my other question... will PTAA only remember changes if album art is labeled "folder.jpg"? Can a program patch be applied to change this? Thank you for your patience!
          • 46226
          • Archd
            • Oct 2017
            Spoon, thanks for the info! I'll apply the change to my audio file database.
            • twiggus
              • Nov 2018
              I'm a bit confused by the comment that nothing uses the "AlbumArt" naming convention. In fact, I have to disagree with that.
              I have been using WMP for years and am having many issues with album art, especially with the latest version of WMP and Windows 10. I would like to get away from using it, but think it would be useful to embed the current WMP album art into the ID3 tag before I make the change. I have a relatively large collection of music - about 10,000 albums and more than 100,000 songs - so doing this manually is out of the question.
              I have been looking for software that will automate the task, but haven't had any luck. PerfectTUNES doesn't seem to work - after it runs there are still thousands of files with no artwork embedded. Maybe I am using it incorrectly, but I keep going back to this "AlbumArt" naming convention thing.
              When I search my music library, it is obvious that WMP is not saving artwork as "cover.jpg". I find maybe 35 files named "cover.jpg" out of 10,000 albums. What I do find is thousands of files named "AlbumArt_{xxxxx}_Large.jpg". I have attached a screenshot for your convenience.Click image for larger version
              So my question is, is there an automated way to embed the artwork from these WMP "AlbumArt" files into the ID3 tag?
              • twiggus
                • Nov 2018
                A couple other things worth mentioning...
                In addition to "cover.jpeg", I also searched for "folder.jpg". There were even fewer of those, though. Maybe a total of 60 "cover" and "folder" files out of 10,000 albums.
                If my research is correct, the number in brackets in the AlbumArt file name is the WMP CollectionID. The naming convention is: AlbumArt_%CollectionID%_Large.jpg
                  • 46226
                  WMP does not simply use Albumart.jpg, it has lots of hidden files with unique identifiers which is tied into their database (collection ID), we cannot associate which of these files goes with which album, only Microsoft can.
