What internal drive to buy for ripping audio cds
  • Dpr
    • Feb 2017
    I have been using a plextor CD-ROM drive for ripping cds. It has a scsi interface and there are driver support issues. So what's the best drive for ripping?
    • 6189
    Re: What internal drive to buy for ripping audio cds
    AccurateRip collects data from all drives, normally this is only used to verify a disc is accurate, but can be reversed to calculate which drives are the most accurate (as measured by lowest % inaccurate tracks). This test was previously run in 2014, 2013, 2012, 2010, 2009 and 2006, as time goes on more submissions give a
    • Dpr
      • Feb 2017
      From the bottom
      "Probably all these drives are no longer manufactured, ebay is your best bet in finding one of these drives."
      Is there a list of Ines that are manufactured?
      • Oggy
        • 703
        From the bottom
        The atapi iHAS (Lite-On) 124 is readily available on eBay, and does the job.
        The thread garym mentioned is well worth a read as it goes into the different versions of the 124 - also several manufacturers badge Lite-On drives.
