PerfectTUNES 2.1 ' Cover ' replacement in Hi-Def.
  • ibuzz
    • May 2016
    Hi to everybody.
    I am on window 7, I recently rip with dbPoweramp CD Ripper 700 cd's in accurate mode , I had 250 cd already rip. My problem some of the cover art are in low resolution. I had to find it manually on the net it's a long job.
    Is there a trick to replace my low res cover for at least a cover of 500x500 or more.
    I saw the tool name Album Art, in the options -Maximum art pixel Seize is at 1000x1000
    - x Embed art selected saying export art to Folder JPG
    - Enable Undo Change.
    My question if I use that tool I do not want to lost all my Hi-Def. cover I have in place.
    I run the program it seam to see a cover art of 256x256 in my xxx album folder when the cover art in there is a 1000x1000 ????
    I do not want to lost all my work by running that tool.
    Can you explain to me how to do it. ibuzz@videotron.ca
    Merci !
    • 46226
    Re: PerfectTUNES 2.1 ' Cover ' replacement in Hi-Def.
    If you run album art, then on the tab 'Low Resolution' only those art would be replaced, the high res arts would not be touched.
    • ibuzz
      • May 2016
      Thank you Spoon at leat I learn the software won&*8217;t toutch my Hi-Res cover.
      Merci
