adding/removing fields in id tags reloads with wrong data
  • inphobia
    • Apr 2025
    • 32
    start with fresh metadata, most likely not needed but when going through this several times to test & write down the steps i did it each time, most likely you can start 6 lines down where it says "now open id tags"
    open perfecttunes
    open accuraterip, go to options, disable "use accuraterip result from id tag"
    close accuratelib, add a few directories to your library in perfecttunes, click "clear database cache"
    open accuraterip, it should now reparse all your files to create a new crc and recheck them online
    close accuraterip
    now open id tags
    select "browse by metadata", "order by sort tags"
    now drill down, for example "artist / album", then open an album so you can see the file details. if you now add or remove a field all current values will go blank. you need to go back to artist / album scren ; then reopen the album to get it to update.
    there is however even stranger behaviour (which is why i looked into it in the first place).
    close your id tags application, reopen it, and while in "browse by files & folders" - "album edit mode", just go the a folder containnig an album, it doesn't even need to be indexed. when the file metadata shows up in the right windop, repeat the previous steps:
    * select "browse by metadata", "order by sort tags"
    * now drill down, for example "artist / album", then open an album (but a different one as the one you selected in album edit mode).
    when you now add or remove a field instead of not showing anything it will show the album you have selected in album edit mode.
    i'll see if i can add 3 screenshots to illustrate.
  • inphobia
    • Apr 2025
    • 32
    example, opened id tags, then drilled down to album:
Name:	Screenshot 2025-06-03 020254.png
    went to browse by tag, drilled down to an album , for this example i disable the comment field by right clicking on the fields and deselecting "comment:
Name:	Screenshot 2025-06-03 020352.png
    and as soon as you remove the field it changes to the album you had select in the first step:
Name:	Screenshot 2025-06-03 020425.png
    just pressing the back button and selecting the album fixes it,so mostly just an annoyance.
    ofcourse i ran into it the first few times with 5500 files in the list
    (metadata -> album -> all albums -> all tracks)
      • 1656
      Problem confirmed and being looked into for the next update, thanks for reporting.
