Could not connect (Running in WIne)
  • martixaim
    • Jun 2015
    Helllo,
    I'm trying to get perfectunes working in wine (Linux), the program itself is running fine but couldn't connect properly to the server. Is it possible to enable a debugging log in the program for troubleshooting this problem. Or could you share some information about the networking library's you are using?
    thanks in advance
    • 46226
    Re: Could not connect (Running in WIne)
    We use our own, which is standard for dBpoweramp as well.
    • martixaim
      • Jun 2015
      Thank you for the response. I'm going to investigate what there is changed in wine. A few versions back it worked correctly.
