2 questions and 2 suggestions
  • allineedis
    • Dec 2013
    The questions:
    Has there been a change in the number of covers that PerfectTUNES pulls initially? Today I noticed that PT only searches to a max of 30 io. the previous 90. Or did I screw some setting?
    How does PT handle multiple covers? Will it remove all covers and replace them with the one you choose in PT? I prefer the latter and I am currently removing the multiple covers in a different program.
    For the suggestions:
    - Is it possible to also mention the KB size on the PT cover? I am using a Bluesound Node and the accompanying app only accepts max 600KB.
    - Because of the above, is it possible to also have a setting with max KB (next to the max resolution)?
    • 46224
    Re: 2 questions and 2 suggestions
    R1.5 (beta) fixes both issues for you:
    http://forum.dbpoweramp.com/showthre...UNES-R1-5-BETA
    It will replace the art labeled as 'front cover' with new art.
