FLAC to MP3 Speed Problem
  • strikex2
    • Jan 2006
    i'm trying to convert a bunch of FLAC files to MP3. I already downloaded the FLAC codec. Anyways, i can convert it fine but the finished mp3 product is playing at a 4x slower rate. the original file FLAC song was about 4 minutes but after convering to mp3, the song is now 16 minutes long. its sounds like a tape player trying to play tape with low batteries.
    i run windows xp on AMD x2 3800+ with 1gb ram if it matters.
    thanks for any help.
    o ya btw, i'm not using any DSP effects.
    Re: FLAC to MP3 Speed Problem
    Check the refresh rate on your FLAC files or the bits (16-bit or 24-bit).
    • strikex2
      • Jan 2006
      how would i go about doing that? is there a program that access info for FLAC files?
        If you have either an unexpired PowerPack or a registered PowerPack, you can right-click on your FLAC files and click "Edit Tag." All of the information should be there. If that doesn't work and you have the PopupInfo on, just hold your mouse over the file and see what the pop-up says.
        • strikex2
          • Jan 2006
          its 16bit FLACs
            What is the frequency or sample rate? 44100Hz/44.1KHz, 48000Hz/48KHz?
            • strikex2
              • Jan 2006
              96000Hz
              • gameplaya15143
                • Sep 2005
                • 276
                Originally posted by strikex2
                96000Hz
                mp3 supports a max of 48khz... and i dont think it can even input 96khz data (i could be wrong though, ive never tried)
                you are going to have to downsample first, then encode to mp3
                  Encode to a 96KHz, 16-bit WAV file, then to a 16-bit 44.1KHz WAV file, then to a 44.1KHz mp3 file. note that you WILL lose tags, but you can use the "Tag from Filename" utility codec to regain them from your filenames.
                  • strikex2
                    • Jan 2006
                    i tried to convert FLAC to WAV however i get a "The CODEC required to compress ...... could not be opened."
                    what codec am i missing? i already have the FLAC file installed.
                      Did you try converting to 16 bit, 96 kHz wave or to 44.1 kHz wave?
