Problem with Greek language in ID tags
  • timmendorf
    • Nov 2005
    I installed version 11 of dbpoweramp converter. At installing I am asked which codification I want to install to read the ID tags correctly. Whatever code I use, Greek does not come up as Greek. In my old version 10 there is a code Smart1v1 as default. This allows me to read Greek as Greek. This code seems to have gone in version 11 of the program.
    Any helping ideas?
    Re: Problem with Greek language in ID tags
    Did you read this: http://forum.dbpoweramp.com/showthread.php?t=8818 ?
    Moved to dMC Support
    Also, are you using dMC r11.5? Version numbers are in dMC Configuration (Start Menu --> Programs --> dBpowerAMP Music Converter --> Configuration --> dMC Configuration).
      In R11.5 on the options page presented after install select ID3v2 (Unicode)
      • timmendorf
        • Nov 2005
        Yes, I am using the latest version dMC r11.5 and yes I tried all codification possibilities.
        Yes I read the posting.
        Version 10 is working fine.
        Version 11 seems to change my language settings totally. I can't even change languages anymore at MS Office Word files.
        I had to use System restore on 3 different computers to get things going again.
        No, I am not a moron, but the version 11 seems to be the Beta product of some careless programmers.
        I am using Audiograbber now, which is slower, but at least runs stable and does not crash my computers.
        :komisch9:
          The underlying problem, actually, is probably that your files have Unicode filenames, which will break any tag display or conversion attempt.
