dMC Audio CD Input and second CD drive
  • dheintz
    • Sep 2005
    • 17
    dMC Audio CD Input doesn't seem to recognize second CD drive. I have two CD drives hooked up as as master and slave to my secondary IDE interface. dMC Audio CD only seems to recognize the CD if it is placed in the 'master' drive. Unfortunately, this is a slower drive than the slave. Is there a way to get dMC to read from the slave drive? Every other ripping software that I've looked at allows you to select the CD drive. Thanks for your help.
    Re: dMC Audio CD Input and second CD drive
    Open Audio CD Input, click on the Options button, click on the line that says cd drive and select your drive.
    Bill
    • dheintz
      • Sep 2005
      • 17
      Thanks. I should have seen that!
