dMC doesn't display correctly when using 'Large Fonts'
  • dheintz
    • Sep 2005
    • 17
    I have Large Fonts (120 DPI) selected in my display adapter (Control Panel | Display | Settings | Advanced | General | DPI Setting | Large) with a screen resolution of 1280 x 1024. With these settings, most of the dMC dialog boxes are mangled beyond being useable. Most software knows how to compensate for large fonts, and it isn't a problem... The only way that I could use dMC was by using normal fonts, which makes it hard for me to read all text on my system. Any plans for a fix? This is a pretty basic Windows UI design and usability issue. Thanks for your help.
  • dheintz
    • Sep 2005
    • 17
    Re: dMC doesn't display correctly when using 'Large Fonts'
    Similar threads yielded similar posts to mine, although Search Forum mechanism did not. The version that I am using was downloaded from your site yesterday, so I assume it is the latest. B.T.W., how would I tell what the current version is from the software? There seems to be no Help ! About dMC... Thanks for your help.
      The very newest version of dMC is 11.5, just released from beta.
      You can best access information about dMC and other dB programs, including your codecs, by checking dMC Configuration (Start>All Programs>dBpowerAMP Music Converter>Configuration>dMC powerAMP Music Converter Configuration).
      Bill
      • dheintz
        • Sep 2005
        • 17
        My version says '11'. Does 11.5 address the aforementioned Large Fonts problem?
          Not that I can find in the Changelog, but its worth a try. R11.5 includes many other bugfixes. Link and changelog below.
            R11 was fixed for Large fonts, which section of the program doesn't work on large fonts?
