Problems with ripping
  • hendrix
    • Sep 2005
    Since I renewed my computer, I can't rip any CDs.
    Every time my computer shows the message:
    CODEC decompression error for '\CdRomTrack01.cda'
    Unable to Rip track - make sure correct Ripping method is selected and CD Drive supports digital audio extraction.
    I've got an Sony cd-rw crx700E cd drive and Windows Xp Professionel. Before I renewed my computer I didn't need any drivers so I didn't installed them yet.
    Can anybody held me.
    thank you
  • Wayne
    • Aug 2002
    • 1254
    Re: Problems with ripping
    Have you checked the "CD Communication" option? Try running dMC Audio CD Configuration which should be on the start menu? What is it set to?
    I have the latest version of dMC and WinXP and I have it set to "SCSI Direct Pass Through".
    Wayne
      Try the latest beta version, it should auto select the 'Windows Internal' option if there are problems.
        Beta link below.
