Right click menu never appeared after install or registration of power pack
  • hooligan
    • Sep 2005
    Just as thread title states. I have looked at the other threads about troubleshooting this menu and nothing has helped (checking file associations, etc).
    I am, however, using 64 bit Windows. Could this be the problem?
    Thanks for the help!
    Re: Right click menu never appeared after install or registration of power pack
    Do you have the latest (beta R11.5) version of dMC ?
    Did you go through dMC Configuration and enable all options under Windows Shell Integration?
    If dMC worked before in the same 64-bit windows environment, it should work now. If W64 is newly installed however, then check this: http://www.devx.com/amd/Article/20342
      IIRC, the right-click menu doesn't work in XP-64, but I may be thinking of the GetPopUpInfo not working.
      The sound of "Windows Shell Integration" makes it sound like it has to be coded differently from the 32-bit integration, but I'm not sure.
        • 46139
        Yes Win64 will not allow shell integration of 32 bit programs.
          Ok, so that settles it. No "Convert to" on right click in Windows 64-bit.
          • hooligan
            • Sep 2005
            Darn, that was always one of the perks of this software. Oh well.
            ...and yes, I had enabled the proper options in the configuration.
