well the problem is that when I am trying to convert .cda to others formats it doesn´t work. I have to PC's and in one I have downloaded de .cda codec and then it started to work but now I cant download the file. in the codecs page it is not there to download, it says that it comes with dbpoweramp
need help
Re: need help
Use "Audio CD Input" to rip your CD. Does your CD show up? If you have more than one CD Drive, click the "Options" button and change the drive selection. Also, try clicking "Advanced" next to the drive selection and changing the communication to "2000/NT Build-In (Limited)" or "Windows Built-In". Also, try downloading the latest dMC beta linked below.
What format are you trying to convert to? What are your system specs (CPU speed, Operating System, RAM)?
