DMC audio to cd imput problem
  • chill1533
    • Aug 2005
    Can anyone help? This feature worked at one time, but
    now it's keeps telling me to insert an audio cd. I've tried everything
    from shutting down zone alarm and virus scan. It must not be seeing
    a drive. From the options in DMC (I have retrieve info when cd is inserted,
    where is it says use cd drive it has no choices.This must be the problem,
    how can it be fixed?
    Any help would be great for this new user
    Thanks!!
    Re: DMC audio to cd imput problem
    Go to dMC Audio Input.
    Click on Options.
    Click on CD Drive and a menu will open up to allow you to choose your drive.
    If this does not occur, please let us know.
    Bill
      The big button for Options in dMC Audio CD Input should offer you the option of selecting a diferent CD drive if you have more than one.
      The little down arrow next to the big Options button also allows specifying the CD comunication method which would work for that drive. This same options can be attained directly in dMC Audio CD Input Configuration.
      For any of this to work you have to be logged into you pc using an administrator account.
        Is your account an administrator account or a limited account? Try changing the CD Communication to "2000/NT Built-In (Limited)" or "Windows Internal (Limited)" depending on your version.
        • chill1533
          • Aug 2005
          Click on Options.
          Bill
          Thanks, when I pull up the CD drive menu from the audio options there are
          no drives, and no options to put one in. I'am using an older version of DMCpowerAMP and as i stated it did work at one time.
          Thanks again
          Chuck
            Adminstrator account? system changes?
            • chill1533
              • Aug 2005
              I'm using windows 98 second edition, and I'm not sure how or if
              I can log in as an adminstrator.
              This program has worked well for a long time, quess it's time
              to find and another one.
              Chuck
              Thanks to all for your input!
                Mabye you need to reinstall the Win98 updates here: http://www.dbpoweramp.com/Windows95-Update.htm ?
                  • 46228
                  and update ASPI (see the support section of this web site).
