DirectShow codec problem
  • ionysis
    • Aug 2005
    Hi
    I have installed the DirectShow Real Audio codec.
    In my dMC Configuration it shows up with .rm and .ram in the Direct Show Decoder(Installed Input Codecs[Read]).
    When i try to convert a rm or ram file to mp3 i recieve the following error message
    "The CODEC required to decompress D:\test.rm could not be opened.
    DirectShow filter for '.rm' not installed, or Audio File Corrupt."
    The file plays fine in Real Player version 10.0
    I am using Windows XP
    Any ideas?
  • Wayne
    • Aug 2002
    • 1254
    Re: DirectShow codec problem
    Have installed Real alternative as well?
    • IndiAndy
      • Aug 2005
      "...Have installed Real alternative as well?"
      I'm having same problem. Where's this "Real Alternative" (codec?)
      IndiAndy
      • IndiAndy
        • Aug 2005
        OK, I installed the latest version of the REAL Alternative but till same problem as above...
        Help?
        • Wayne
          • Aug 2002
          • 1254
          Did you install the File Splitter? application that came with Real Alternative?
          Can you play the files in WMP. This will prove that the Direct Show filters are installed properly? Or the Media Player classic (comes with Real Alternative) to will check that Real Alternative is installed properly?
          Wayne
          BTW How big are these ra and ram files?
            • 46228
            Tried rebooting the computer?
