I have been trying to downmix 6 channels audio files into 2 channel ones (ogg/aac -> wave). The process completes normally, but the resulting file is full of breaks, pops, and crackles. These artifacts are not in the original files. I have tried to convert from AAC and Ogg formats directly but get the poor quality. I have also tried converting ogg files (using oggdec and faad) into multichannel wave files (which still have no artifacts), and then using dmc to convert those into stereo wave files. Artifacts still remain. Other programs such as foobar2000 and faad (with downmix option) can convert these files with no problems at all, but I like dmc and would love to continue to use it. :smile2: Any ideas on fixing this problem is appreciated. Thank you.
Converting 6 channels to stereo and quality
Re: Converting 6 channels to stereo and quality
Try the latest dMC beta and AAC codecs. Also, the newest dMC AAC codec uses FAAD to decode AAC files.Lt. Data
Please don't PM me for tech support. -
AAC 6 channel >> wave 2 channel is ok
wave 6 >> wave 2 has problems?Comment
But your WAV 6-channel file plays OK? There aren't any artifacts in it?Lt. Data
Please don't PM me for tech support.Comment
After trying more tracks, it seems to do it converting from both AAC, ogg, and wave. The files it occurs on are pretty low in volume, so I'm not sure if that has anything to do with things or not. Lounder tracks don't seem to have artifacts present (at least I'm not hearing them). Here is how I've been testing things :
aac -> FAAD -> 6 channel wave (plays fine, no problems) -> dbpoweramp -> 2 channel wave (artifacts occur)
ogg -> oggdec -> 6 channel wave (no problems) -> dbpoweram -> 2 channel wave (artifacts occur)
aac -> FAAD (w/-d option) -> 2 channel wave (no artifacts)
ogg -> oggdec -> 6 channel wave (no problems) -> foobar2000 (5.1 downmix) -> 2 channel wave (no artifacts)
I hope this helps clear things up.Last edited by swyn; July 11, 2005, 08:49 PM.Comment
Perhaps you could email one of the files it does it on, slowly a new dbpoweramp will be ready where the channel mapping (and downmix) percentages can be set:
I know for 6 ch to 2 I use:
Lt=L+0.707*(C-SL-SR+LFE)
Rt=R+0.707*(C+SL+SR+LFE)
Obviously depending on the audio values it is possible to clip, a later version of dMC will allow the percentages to be set.Comment
Hi Spoon
Is the - and the + supposed to mean adding the channels inverted and non-inverted?
Also I don't quite get why you would add the Surround Right to tje Left channel and the Surround Left to the Right channel?
I am downmixing a 5.1 DTS album to stereo by trial and error with regards to the levels because just mapping the channels using ie -50%/-6dB when mapping the LFE to both front channels resulted in massive clipping (even though all channels had already been lowered by 2dB). I have solved that but can't seem to get the levels of the surround and center channels right.
Best regards,
JensComment
You can use the DSP effect 'Channel Map' and apply the channel exactly as you wish. But remember you are squashing 6 channels into 2 so have to be careful of clipping.Comment
Yes and it Works great. But I am wondering if the phase of the surround channels should be inverted. Do have advice regarding that?
BR/JensComment
It has been over 10 years ago when I worked on it. I used best practices at the time.Comment
Yeah I did see that the tread was quite old but hoped for the best
I found the ATSC standard and are experimenting with different settings
http://atsc.org/wp-content/uploads/2...-201212-17.pdf
Thanks for the hint about best practices, that lead me straight to the standard
Br//JensComment
