Problem with AAC Codec (Release 5)
    I have tried installing the new AAC encoder/decoder (release 5). I did this after updating to the new mp4 encoder/decoder and updated some other codecs as well. I uninstalled my previous version of AAC. I was able to get it to work for a while. But now I have a problem.
    I can play AAC files using this new codec and it appears on my dMC codec menus. However, when I try to rip to AAC (quality setting vbr 300) I get an error box whose title is: "aacenc.exe Unable to Locate Component" with the message: "This application has failed to start because ia32math.dll was not found. Re-installing the application may fix this problem."
    Repeated re-installs (with and without uninstalls and restarts) have had no effect. Yes, I always download my codecs to their default locations and yes I did click to locate the codec in the default location.
    Any help on this would be welcome.
    Bill Mikkelsen
    Re: Problem with AAC Codec (Release 5)
    Manually browse dMC's compression folders and make sure that aacenc.exe is where the codec is pointing to.
      The aacenc application file is in the Advanced Audio Coding (CLI) folder in the dMC compression folder. Yes.
        I assume you have the AAC codec pointing to it? Did you find the ia32math.dll in the same folder?
          Yes.
          No. I see no sign of the ia32math.dll. Even did file search of my drives. No luck.
          • Wayne
            • Aug 2002
            • 1254
            I'd try a google search for ia32math.dll and see if you can locate a copy then install it into the same folder as accenc.exe
            Wayne
              Zip removed as no longer needed.
                Christina & Wayne-
                Thanks. I'll check it out when I get home.
                Can you confirm that the .dll file belongs in the same folder as aacenc.exe?
                Bill
                  So far, no good.
                  I get an error on Christina's attachment indicating that the archive is corrupt. I did find another source for the ia32math.dll and placed it in the same folder as aacenc.exe. The one improvement is that I no longer get the error message about the missing .dll. On the other hand, when I try to rip or convert to aac all I get is a 1 kb file which won't play.
                  I guess it is back to trying a few uninstalls/reinstalls but I have a feeling that something else is wrong here.
                  Further suggestions would be welcome if you have any.
                  Bill
                    Mabye try redownloading the AAC codec and then reinstalling it? Make sure you delete the folder when you uninstall if it isn't done automatically.
                      No luck there. Uninstalled. Deleted folder. Redownloaded and installed codec. New install showed faac.exe and ia32math.dll files but no aacenc.exe file. Wouldn't convert even if I pointed the converter to faac.exe.
                      Need to go to bed for now and hope things go better tomorrow.
                      Bill
                      CORRECTION: The new install showed faac.exe and an Options file. It did not contain either aacenc.exe or the ia32math.dll files. Sorry about the misreporting.
                        My zip corrupt? Hmmmm.... Not likely, unless the actions of uploading it here and your downloading it corrupted it. I simply zipped the one I have in the folder C:\Program Files\Illustrate\dBpowerAMP\Compression\Advanced Audio Coding (CLI) , which works fine for me. I wonder if this file comes in different flavors depending on OS. I am using W2K.
                        The dll file size is stated as: 688,128 bytes . The zip filesize is 130 KB (134,061 bytes) and size on disk is 132 KB (135,168 bytes) .
                          I think it highly likely that the problem is on my system's part, namely because the situation with this codec continues to deteriorate. Since my last post I deleted my download file for the AAC codec, uninstalled the codec, checked to make sure the folder was removed, restarted my computer, redownloaded the AAC codec from Codec Central, reinstalled. The new AAC codec folder fails to show either aacenc.exe or the ia332math.dll (although I can always add that manually).
                          I am running XP SP2. Any insights as to why I cannot get a complete install of this codec?
                          Bill
                            • 46139
                            It was renamed, your older one was psytel, this new one is faac and appears as 'Advanced Audio Coding (CLI)'
                              As should go without saying...You are right, Spoon.
                              The new AAC codec does not need aacenc.exe nor ia32math.dll. The faac.exe file and options were all that was needed. The codec is working right, which it was not last night with what appeared to be the same folder contents (codec would act like it was converting but only create 1 kb files).
                              Any way, thanks to all of you for your help and assistance.
                              Bill
